Edit "Simulation details" with code in sit 5
Hi everybody.
I am using SIT 5 to run a "mdl" on my cRIO. I' am using the function "File Playback" and it works fine, one time.
I want to be able to read the file on my command, it want reset after its been run (loop if want work in my application). So the next time the read starts from the last element and stops (no more file).
It is possible to use "Simulation Details" to rewind it manually but I want to do it in the code and not by hand.
Is this possible?
/M
Message 1 of 1
(3,290 Views)
