Display data from an acquisition system other than NI materials connected over ethernet
Hi ,
I seek to code a LabVIEW interface capable of displaying analog signals
relating to vibration sensors each installed on industrial machines via a
monitoring and data acquisition device connected on Ethernet Local network
Knowing that I have a system of acquisition other than NI acquisition materials
so i would like to know whether i can visualise signals on LabVIEW by using Visa
TCP/IP for exemple. if not what are the possible solution?
Ameni Ben Yacoub
(3,201 Views)
Hi Ameni,
That should definitely be possible. If you give some more information about the DAQ device, we can probably give more detailed information about how you can proceed.
As you say, VISA can be used to communicate over TCP/IP. This might be one of the possibilities.
GCentral
(3,167 Views)
Thank you for your answer, my DAC is a state / machine monitoring system for IBU-NG montronix consisting essentially of the PulseNG vibration sensor and the IBU-NG interface.
https://montronix.com/en/about-us/ibu-ng-en.html
(3,156 Views)
I hope from anyone can help me not to hesitate at all .. anyone knows about how to display anlog signals on labview with a DAC system other than NI materials.
Thank you.
(3,128 Views)
