Could we add many separated applications in a cRIO real time?
Hi every one,
I have a stable system running in cRIO - 9063. I want to add a second application who manages another task in the system.
I dont have a project to modifier or recompile the running application in cRIO. Could we have another ways to installer the second application into cRIO like installing many applications in Window or Linux?
Thank you.
Nguyen
(2,181 Views)
Hi Nguyen,
Unfortunaltely, this is not possible. You can have only one real time application running on your cRIO. However, there are ways for you to deploy plugin applications that you can manually load each time you reboot the controller. You'll find attached an example of how to do this using a USB stick that contains a new application:
http://www.ni.com/example/31579/en/
Karim
(2,145 Views)
