Conversion of Current to Temperature
I am getting started with LabVIEW and would appreciate some help in converting a current output(0-20 mA) from a LUMASENSE IGAR 12-LO 2 Color Pyrometer. I am receiving the output in my NI 9203 module that is attached to a NI cDAQ-9174.
I am unsure as to how to do the conversion/scaling from current to a readable temperature in C.
Any help would be appreciated.
Thank you.
(1,415 Views)
It would also depend on the range for the sensor.  But your conversion should be Reading*(Max-Min)/(20mA)+Min.
(1,409 Views)
The range is between 400 and 3300 °C.
So I'm guessing I input that equation into a formula block and I should be good to go?
Please see attached picture.
(1,403 Views)
I avoid Express VIs as much as possible.  They tend to hide too much information and are inefficient.  For the calculation, just use the basic math nodes.
(1,391 Views)
Thank you so much for the help!
(1,387 Views)
