CompactRIO configuration
Hi
I did all of that..and i've attached a copy of my project.
But when i follow the steps listed http://www.ni.com/white-paper/5075/en i dont find the folder called "items to move"
Message 31 of 38
(2,881 Views)
Message 32 of 38
(2,880 Views)
Hi Beau H
Now it's ok i correct the errors of the FPGA VI by doing that:
But i still have a compilation problem..i've attached an image(.png) of the compilation status
how correct that?
Message 33 of 38
(2,875 Views)
Hey moonm,
Check out this KnowledgeBase http://digital.ni.com/public.nsf/allkb/2C6ED1D20C9FF80D8625779D00675A2E, and verify you are setting the target in Project to your FPGA and that you have the Xilinx Complier tools installed.
BeauH
Message 34 of 38
(2,865 Views)
Hi BeauH
i miss the xilinx compile tool
Now it's ok i've installed the xilinx compile tool 11.5
But after almost 12 min of the compilation process this error appears
what does that mean?
Message 35 of 38
(2,859 Views)
Hey Moonm,
While I can't read the error message I think this KnowledgeBase covers it http://digital.ni.com/public.nsf/allkb/66FE4C3781B66A1886257961004223FD?OpenDocument
Good luck.
BeauH
Message 36 of 38
(2,851 Views)
Hi Beau H
Thank you for your help
But does not fix the problem, also i repair the xilinx tool 11.5 and the error persists
regards
Message 37 of 38
(2,845 Views)
Hey moonm,
is it possible for you to create a simple test program with only a few vi's and see if you can successfully compile it. We just want to test and see if you can successfully compile anything.
BeauH
Message 38 of 38
(2,840 Views)
