07-30-2009 02:52 PM
I plan to using a NI speedy board to generating a continuous sinusoidal sigal with specifed frequency and received by the NI Single Board RIO on a point by point basis. I'm using a headphone cable wiring the audio output of the speedy board to AI0(DIFF mode, +-1V) and GND of NI Single Board RIO. The specification of the audio output of speedy board says that the max working voltage for analog outputs(signal + common mode) is 1.41V. I don't know if there's a kind of relationship between the amplitude of the signal wired to the output I/O terminal on the block diagram and the physical output signal. According to my observation, the received signal is pulled up a little bit. Is there a way to remove completely the DC component?
Another issue is that I'm expecting a sampling rate of 8kHZ for the RIO board, but it seems that the RT system can only samples at around 2kHz at most. Is there any way to make it working.
The project file is attached as follows,
Thank you for your help.
07-31-2009 09:21 AM
