Can I use USB external storage on cRIO9076?
Hi this is Lee.
 Currently, I'm using cRIO 9022 with external USB hard-disk drive. So I put my data in it.
 Like 9022, Can I use USB hard-disk as a data storage in 9076?
 Thank you.
 Lee.
(5,699 Views)
Accepted by topic author Automation777
Yes you can, but I am currently experiencing issues downloading data files via FTP.  Hence the form trolling.  Basically, I have too many files and the ftp client on the crio can't handle so many files.
(5,693 Views)
        I am trying to store the data on external usb drive using usb port which is available on crio-9024.I have tried many usb drives, but they are not getting detected in crio.
Kindly help.
(5,494 Views)
We use USB sticks with the 9025 and have no problems with the controller recognizing the stick.  Try ftp-ing to the controller, cd to u:, if that command works, try to mkdir or otherwise create something on the stick.
(5,492 Views)
You must reboot the CRIO with the USB stick in place or it will not be detected. It does not autodetect the same as a PC. Hope this helps.
Buddy Haun
Certified Trainer, Former Alliance Member, LabVIEW Champion
(5,484 Views)
