BackUp of cRIO-driver
Hello everybody,
at the moment we are setting up a new computer with LabView 2021. Previously we were using LabView 2014 on a different computer which shall be kept like it is to have always the possibility to step back to the old running version of LabView if there are any malfunctions in the 2021-version.
In addition to the software, we are using a cRIO-9067 which was used with the 2014-version and shall be used again with the 2021-version. To make sure, to be always able to step back to the 2014-version we are looking for a way to backup the driver-software of the cRIO as we are afraid that the driver is updated once I connected the cRIO with the 2021-version. We guess that in that case we wouldn’t be able to use the 2014-version in connection with the cRIO. We have to avoid this scenario.
As operating system on the cRIO we have "NI Linux Real-Time ARMv7-A 3.2.35-rt52-2.10.0f0" and the firmware version "3.0.1f0".
Our first general question is: Does anybody know if the cRIO-driver is updated automatically when we connect it to a newer desktop LabView-Version (here 2021) or is absolutely necessary to do this update manually e.g. by USB-Stick/Ethernet?
And our second question is then, what would be the best way to backup my cRIO-driver? So far, we have researched the following methods:
Replication and Deployment Utility (RAD): This looks like the most promising solution but when we wanted to install the software it said, that updates for system components were going to be done. That’s why we didn’t finish the installation as we wanted to prevent automatic updates to happen to any system components of the 2014-version. This version shall be untouched.
We have also tried the “Create-Image (Folder)”-Function: We have tried to implement this function into our main VI and also created a separate VI but always got the error message “−2147467263 - Not implemented”. As “session in”, we selected the NI-cRIO-9067. A screenshot of th setup is attached. Is this method even suitable for creating a backup of the cRIO-driver software or do we have to work with it?
Thank you very much for your help.
LenJo
Further information about our software versions:
cRIO:                                                           14.5.0
NI-DAQmx Device Driver                            14.5.1f1
NI-DAQmx ADE Support                             14.5.1
NI-DAQmx MAX Configuration                    14.5.1
DIAdem 2014                                               14.0.0.5641
NI I/O Trace                                                 15.0.0f0
LabVIEW Runtime 2012 SP1 f9                  12.0.1
Measurement & Automation Explorer          15.0.0f0
Measurement Studio                                   Visual Studio 2010 Support - See individual versions below.
     DotNET
          Common                                           13.5.40.173
          Common (64-bit)                               13.5.40.173
NI-USI                                                         14.0.0.5640
NI PXI Platform Services Configuration      15.0.0f1
NI PXI Platform Services Runtime              15.0.0f1
NI-RIO                                                         14.5.0
NI R Series Multifunction RIO                     14.5.0
NI FlexRIO                                                  14.5.0f0
NI-PAL Software                                         15.0.0
NI 1588-2008 Network Management         15.0.0f0
NI-Serial Runtime                                       14.0.0f0
NI-Serial Configuration                               14.0.0f0
NI System Configuration                             15.0.0f0
NI-VISA                                                       15.0.1
     NiVisaServer.exe                                   15.0.0.49152
     NIvisaic.exe                                           15.0.0.49152
NI-VISA Runtime                                        15.0.1
LabVIEW                                                    14.0.0
     Database Connectivity Toolkit                14.0.0
     Datalogging and Supervisory Control    14.0.0
     FPGA                                                     14.0.0
     MathScript RT Module                           14.0.0
     Real-Time                                               14.0.0
     Real-Time Trace Viewer - LabVIEW 2014 Support    14.0.0
     Report Generation Toolkit For Microsoft Office   14.0.0
LabVIEW Runtime 2013 SP1 f2                  13.0.1
LabVIEW Runtime 2014 SP1 f11                 14.0.1
(539 Views)
You should be able to reload whatever version of LV software into your cRIO that is installed on your PC.  You'll do this through NI-Max and it will give you the option to install from what is available on the PC.  Just connecting your cRIO to the PC won't update your SW, you'll have to follow specific steps to do that.
https://www.ni.com/en/shop/compactrio/compactrio-developers-guide.html
(292 Views)
