Assigning period in timed while loops from local variable
I'm trying to assign a local variable to a timed while loop running on a MyRIO to control the rate at which the loops run, but when I do this the loops do not run. Any help appreciated.
-T
Message 1 of 13
(4,597 Views)
Hello TallGrass
I would like to know if you are in the VI is located in the FPGA or in the Real Time Target. It is just to try something here in my system. Also, feel free to attach a screenshot of your code.
Regards
Message 2 of 13
(4,562 Views)
It is in the Real-Time Target. I don't have a copy of the code as I am away from my office but will upload a screenshot as soon as possible Monday morning. Thanks -T
Message 3 of 13
(4,550 Views)
Hi TallGrass
I will be waiting for that info
Regards
Message 4 of 13
(4,543 Views)
Here is a shot of my issue.
When I assign a value of 1000 to the sample period in the top loop with a local variable it doesn't run the loop, however the bottom loop still runs.
When I assign the value in the configuration box of the timed while loop it works.
-T
Message 5 of 13
(4,539 Views)
Hello TallGrass
Thank you very much for attaching the screenshot.
I am wondering about where are you writing the local variable? I am asking that because it might be possible in the specific moment where the time loop reads the local variable it did not have any value loaded yet.
On the other hand I would like to know why did you use a local variable to set it?
Regards
Message 6 of 13
(4,531 Views)
The local variable is assigned in the frame before in a flat sequence. It is used a handful of other times to the period for timed while loops throughout my code, and thought it'd be better to assign it this way rather than connecting it directly to each loop. Maybe I should try connecting it directly?
Message 7 of 13
(4,527 Views)
Hello TallGrass
Do you mean using a wire? Let's try that.
Regards
Message 8 of 13
(4,516 Views)
A wire still doesn't work. When I probe it it says no value has been assigned.
I guess I am confused on the order of operations being performed and am unsure why it is not being read before the loop starts
Message 9 of 13
(4,507 Views)
Hey TallGrass
I was trying to recreate the issue you are having here and I realized something but first of all I would like you try:
  1. Delete the local variable you have wired in the dt loop parameter
  2. Right click on dt parameter then create a constant (setting a value in that constant)
  3. Make sure that works
  4. I supposed you create the local variable from a control so, let's modify the Representation right clicking the control then select Representation and select I64.
  5. The wire and local variable have to have color blue.
What I was thinking is that you were using wrong number representation for the dt Parameter. See the screenshot
Let me know if something changes
Message 10 of 13
(4,501 Views)
