[Ask] EMG Signal Measurement with PCI NI 6220
I am a newbie, and need some help.
Currently I have build a EMG Signal amplifier using OP Amplifier, and then I want to view the signal in the computer using PCI board NI 6220.
Do you know any info where I can get the sample program (source) using Visual Basic 2005 or Visual C++ 2005, where I can connect my circuit via NI 6220 and display the signal in the monitor?
Thank You very much for your help.
Best Regards,
The-F
Message Edited by The-F on 11-28-2007 11:53 AM
(4,137 Views)
Hi The-F,
If you are using NI-DAQmx, the samples for Visual Basic .NET and Visual C++ 2005 can be found in
C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DotNET2.0
C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\MStudioVC2005
For more details, please refer following.
http://digital.ni.com/public.nsf/allkb/E0D14AB889CBF8E5862572B8006B22D3?OpenDocument
Mineo Kamiya
Application Engineer
National Instruments Japan
(4,120 Views)
Hello Mineo Kamiya,
Thank you very much for your reply.
Yes, I also have seen in many posts, that I can find examples in the /examples folder....
But, this is really strange in my computer, I can't find dotnet2.0 and mstudiovc2005 under examples folder...
I also have try to search in the 2 CDs(1 driver cd and 1 documentation) which come with the PCI board...
I am sure, I am missing something there... Could you please assist me in what folder where I can find the examples files in the CD? Or, are the files available to be downloaded online?
Thank you very much.
Best Regards,
The-F
(4,117 Views)
Hi The-F,
You may find following information useful.
Location of ANSI C NI-DAQmx Shipping Examples and DAQmx Library File for Windows
http://digital.ni.com/public.nsf/allkb/FB26BDA52FFFD4EE86257124005C36C3?OpenDocument
If you still can't find the examples. you might have to re-install NI-DAQmx. Make sure "Microsoft Visual C++ and Basic support" options are checked.
Mineo Kamiya
NIJ AE
(4,108 Views)
Hello M. Kamiya,
Thank You very much for your suggestion.
At last I have found it Smiley Very Happy
Best Regards,
Arifin FinLy
(4,104 Views)
