Analog Input Example -> Dynamic Data Output
Hi!
I am using the "Analog Input Example" to substitute a DAQmx Express VI (DAQ-Assistant).
How can I combine the measured data with the measuring-time so that the Output of the Analog Input Example is really the same like the one of the DAQmx Express VI?
Because the "VI Convert Waveform to DDT" does not wok for me.
Is there any advanced example which belongs to this problem?
TIA,
  Manuel
Sorry for my bad English.
(3,432 Views)
Hi Manuel,
can you tell me why the conversion VI did not work? What type of data does the DAQmx Read.vi output?
I couldn't find any example named "Analog Input Example". Where did you get it? What version of LabVIEW do you use?
I wrote a simple example program that acquires voltages from one channel and converts the waveform to dynamic data.
You can take a look at it and tell me if it works that way.
David
(3,427 Views)
