Additional CAN ports on the sbRIO-9607
The sbRIO-9607 supports 2 embedded CAN ports by default - CAN0 and CAN1.  Is there an easy way to add additional CAN port logic to the FPGA using the same IP as the first two ports?  Otherwise we will have to import an additional IP Core to provide the CAN logic.
Ryan
(1,662 Views)
Hello
For this specific model, it seems we don't have an easy way to do it.
Usually, you can do that using the CLIP Editor as you can see on the next links.
http://zone.ni.com/reference/en-XX/help/375106C-01/sbrioclipgenerator/clip/
http://zone.ni.com/reference/en-XX/help/375106C-01/sbrioclipgenerator/peripherals/
To import the IP you can follow the next
http://www.ni.com/tutorial/7444/en/
Regards
(1,635 Views)
