9215 is 16 bit adc and i can not find the highest resolution of it
Dear sir
I am using the signal 0 - 5 v dc for a controlling purpose but i saw the control is performs in 5 steps only (on the other way 1 volt resolution )how i can do
(3,862 Views)
Can you be more specific where you only see 5 steps.
In your code you convert the fixed point (FXP) data from the 9215 AI module to a 32-bit integer (I32). This will result in only 5 possible values for your data, and any code which is a result from this value will only have 5 steps. Don't convert to I32 and use the data as fixed point instead.
authored by
Christian L, CLA
Systems Engineering Manager - Automotive and Transportation
NI - Austin, TX
(3,841 Views)
Accepted by topic author saini
Thankyou i achive
(3,815 Views)
