ROS for LabVIEW(TM) Software
How to set up a simple service client and provider?
Is it possible to have a tutorial on how to set up a simple service client and provider? It is not clear at all how to make it work.
Thank you in advance!
In the attached zip there are three files, one client, one provider, and one simple service message definition. When I run the client the following error shows:
Error 403302 occurred at Error in finding the queue in GetQueueValue.vi:470001
This error code is undefined. Undefined errors might occur for a number of reasons. For example, no one has provided a description for the code, or you might have wired a number that is not an error code to the error code input.
Additionally, undefined error codes might occur because the error relates to a third-party object, such as the operating system or ActiveX. For these third-party errors, you might be able to obtain a description of the error by searching the Web for the error code (403302) or for its hexadecimal representation (0x00062766).
Message 1 of 1
(4,967 Views)
