Quick Drop Enthusiasts
User Interface Manager - Quick Drop Plugin
Hello All, I created some time ago a tool for UIs in LV. You can find it here: http://forums.ni.com/t5/UI-Interest-Group-Documents/User-Interface-Manager/ta-p/3539490
# Newest Features
Newest version 1.1.1.67 includes a QuickDrop shortcut for capturing the UI state into an XML file. Now, to capture state of the UI you just need to press Ctrl+Space -> Ctrl+U. The file generated this way will have the same name as the VI and the extension XML. It can be then loaded using the API or the UI Manager Tool from the tools menu.
An additional option you can use is the <Ctrl><Shift>+<U> which will take the text from the QuickDrop ComboBox and use this text as the UI state name.
Please check it out, play with it and let me know what you think. Thanks!
Piotr Kruczkowski
Certified TestStand Architect
Certified LabVIEW Architect
Message 1 of 1
(3,553 Views)
