Quick Drop Enthusiasts
Quick Drop Palette Object Shortcuts (German)
NOTE: If you are using LabVIEW 2016 or later, these shortcuts are automatically installed on your first use of Quick Drop, assuming you did not copy over your LabVIEW INI file from a previous installation. Thus, this page is only necessary if you are using LabVIEW 2015 or previous.
The attached file contains NI's standard list of Quick Drop object shortcuts in German.
Instructions:
Copy the lines from the attached text file into your German LabVIEW INI file (for LabVIEW 8.6 and later).  No LabVIEW restart is required.  Note: If you already have your own Quick Drop shortcuts configured, you will need to manually merge your existing QuickDropDiagramShortcuts and QuickDropPanelShortcuts INI entries with these, keeping in mind that the lists are sorted alphabetically by shortcut.
(5,369 Views)
Thankyou Darren
One small correction the shortcut for "rndd" in "QuickDropDiagramShortcuts" should be--> rndd:Auf nächstkleinere Zahl runden
(4,356 Views)
Thanks, nik. I have corrected the file.
(4,357 Views)
