Power Electronics Development Center
three-phase four-wire (four leg) inverters
Has anyone created any cRIO FPGA code for three-phase four-wire (four leg) inverters that they'd be willing to share?  Is there any in the NI code library?  I've searched through the master library of examples and haven't found anything, but maybe I'm not looking in the right place.
Steve
Steve Drouilhet
(6,153 Views)
Here are a two new reports from the National Renewable Energy Lab (NREL) on numerous types of converter controls implemented with NI CompactRIO and Semikron including 4-leg inverter with zero-voltage switching (ZVS), isolated DC-to-DC (dual active bridge bidirectional DC-to-DC converter) with zero-voltage switching (ZVS), buck boost, solar MPPT, …
1. Integration of a DC Transformer, Four-Leg Inverter, and Flexible Grid Input Into the Consolidated Utility Base Electrical (CUBE) System, NREL/TP-5D00-66612, Jun. 2016 http://www.nrel.gov/docs/gen/fy16/66612.pdf
2. Consolidated Utility Base Energy (CUBE) Performance Test Report, NREL/TP-5B00-62768, Dec. 2014 http://www.nrel.gov/docs/gen/fy16/62768.pdf
In particular, here are the references NREL used for the 3-D SVM:
  1. Zhang, R. High Performance Power Converter Systems for Nonlinear and Unbalanced Load/Source. Ph.D. Thesis. Blacksburg, VA: Virginia Polytechnic Institute and State University, 1998.
  2. Zhang, R., Prasad, V.H., Boroyevich, D., and Lee, F.C., “Three-Dimensional Space Vector Modulation for Four-Leg Voltage-Source Converters,” IEEE Transactions on Power Electronics (17:3), May 2002, pp. 314–326.
(5,356 Views)
4leg inverter output voltage control with Repetitive Control can be download from the PED-board website: www.ped-board.com
Go to download section.
Software is designed for the PED-Board but it can be definitely used for the cRIO.
Cheers,
AL3
(5,356 Views)
AL3,
It is not clear which file in your download section contains the code you are referring to.  Please specify.
Steve
Steve Drouilhet
(5,356 Views)
Hi Steve,
I apologize, wrong info. 4leg inverter Repetitive Control project is in the PROJECTS folder: SUPPORT -> PROJECTS.
Cheers,
AL3
(5,356 Views)
