Power Electronics Development Center
ni max can't add software to 9607
Hey
I'm trying download software for my 9607 but my NI MAX can't add software to it
this is how my max and web congifuration  looks like
could somebody please tell me how to fix it
thank you
(4,964 Views)
Hello Longwu2000,
I might be wrong but as far as I know, as long you would have Inconsistent IP setting, you would not be able to add/remove software on the sbRIO. You should first solve this problem before going further.
Wish the best continuing your development,
Julien
Julien Roland - District Sales Manager
NI Belgium - Technical Support
Don't forget to rate a good answer
(4,428 Views)
I might need the mac address for to login to the university first
but today when i open the MAX I can't even find the device
could somebody please help me out
thank you
(4,428 Views)
Make sure you have the latest CompactRIO drivers installed (CompactRIO 15.0 Device Drivers) and that you've rebooted since installing them. It won't appear if your drivers are an older version. Disable WiFi on your computer so there is only one Ethernet connection. Make sure you are connected via copper Ethernet cable and on the same subnet (connected to the same Ethernet switch/router). Make sure your computer has a valid IP address. Cycle power on the sbRIO-9607.
See the module 1, exercise 1 material here:
NI Power Electronics Control Design V Training Course
In particular, view the first tutorial video which demonstrates how to setup and configure your sbRIO GPIC on the network and download the GPIC Reference Design code to the real-time operating system and FPGA.
You may also be interested in the older troubleshooting advice here:
https://decibel.ni.com/content/message/63361#63361
(4,428 Views)
