Power Electronics Development Center
generate triangle wave of variable frequency upto 20kHz using NI GPIC analog output
I need to generate a triangle wave of variable frequency upto 20kHz frequency and amplitude of 1V using NI GPIC board analog output. Can someone suggest me ways to get a headstart as to how to do that using labview fpga?
(4,085 Views)
According to specs (http://www.ni.com/pdf/manuals/375960b.pdf    -- page19) AO update rate is 1KSample/s min. Therefore, if the triangular wave is made of 100 points, the maximum guaranted frequency would be 1K/100 = 10 Hz. Which is far from the 20kHz requiered.
(3,359 Views)
