Power Electronics Development Center
Voltage and current sensor(LEM) outputs measurement using Simultaneous analog inputs ports of NI9683 using SBRIO 9606.
I am using NI 9683 with SBRIO 9606 for inverter control. The voltage and current sensor(LEM) outputs are given to the Simultaneous analog inputs. However, the waveform on the front panel is not same as the given input signal.
Please share how to select the offset values for the Simultaneous analog input ports.
In the given model NI 9683 getting started the offset value is taken as 2.49. How it is selected.
Message 1 of 1
(3,735 Views)
