Power Electronics Development Center
Software based PWM signal
Hello everyone,
I am doing a project on co-simulation, now I was wondering if anyone knows how to generate a fully software based PWM signal in Labview.
Every example I find about it is using a fpga or myDAQmx, but I do not use one of those, it only needs to work software based.
I hope someone can further help me.
Kind regards
Wlew
(6,048 Views)
Hello WIew,
I'm not sure to clearly understand the issue. But if you want to generate a square wave and control its duty cycle, pick a look in he paltette Signal Processing » Waveform Generation (requieres Full Development System):
Let me know if it helps.
     Mathieu.
(4,788 Views)
Hi Mathieu,
Thanks for the reply, I tried to work with the square Waveform.vi, but I need a frequency of 50KHz and then LabVIEW gives me an error. The error has something to do with the sampling frequency and when I change the sampling frequency to a value that is twice the frequency (Nyquist ratio) the Square waveform.vi gives me an triangular output. I am trying to figure out what is the problem, but at the moment I have no idea what it could be.
Best regards
Wlew
(4,788 Views)
Okay, just adjust the sampling info. Nyquist ratio is a theorical value. In practive, you often need 5 or 10 times your signal frequency as sampling frequency. If your requiered frequency is 50kHz, try with 1MS/s, this will allow a 5% resolution for your PWM. Be carefull with the number of samples: you can generate an unnecessary hudge amount of data...
(4,788 Views)
Hi Mathieu,
Thank you very much for your help, when I set the sampling frequency at 1 MS/s like you said, I get a nice square wave again and I can properly adjust the duty cycle.
Thank you for your help
Kind regards
Wlew
(4,788 Views)
hi,
instead of trying to create PWM signals from square waveform ( by adjusting the duty cycle), try to implement your own PWM technique.
You can easily generate sin and triangular waveforms and implement Sinusoidal PWM with variable modulation index by controlling the amplitude of the waveforms. or you can implement some other PWMs also...
if its fully software based PWM means, u can try it easily in labview..
Thanks & Regards,
Ilamparithi Tamizhanangu
(4,788 Views)
