Power Electronics Development Center
Local compiler issues in LabVIEW 2015
I have been using LabVIEW 2015 for some time now and I have successfully used the local compiler for compiling my VIs in 2015. But after a few weeks hiatus as I tried recompiling some of my earlier work I can't. I get the following error.
I tried re-installing NI LabVIEW FPGA Xilinx ISE 14.7 tools, but I get the following error,
I've also tried installing Xilinx Vivado 2014.4 f1, only to receive the following error,
And I haven't been able to locate NI LabVIEW FPGA Xilinx Vivado 2015 else I would have posted the error I receive with that installation too..
Can someone please suggest a remedy to this problem. I have built some inverter control algorithm for a project I've been working on and time is of the essence.
Ps: I remember I had the same issue everytime I update LabVIEW. It would be excellent if NI would make the upgrade process more streamlined.
(4,700 Views)
I have one PC with the same issue. Never solved!
(4,142 Views)
I have found the solution to my problem. First I uninstalled all the Xilinx compilers from earlier by going to NI-MAX>system>software>labview 2015 f2.
Then I installed the latest compiler that I downloaded from "http://ftp.ni.com/support/softlib/labview/labview_fpga/fpga_module/2015/Windows%20Tools/2015Xilinx14..."
I hope this helps anybody else who's been having this issue.
(4,142 Views)
