Phase Matrix Products
FSW - 0010 Synth Power Control and Parameter Update Time
I have been given a QuickSynth FSW - 0010 to use, and I have two concerns:
1. I can't change the power output of the synthesizer, both in the UI and programming-wise. I have read that you need Option 2 in order to change the power. How do I check which option I have, and how do I change the power output? By default on the UI, the option value is an immutable "0008".
2. How long does the synthesizer take to update parameters? I have been using the module "pyvisa" to send instructions from a Jupyter notebook to the synthesizer through a usb port, and have noticed that sometimes I need to add a sleep command before I continue with the program.
Message 1 of 1
(2,248 Views)
