Abstract: More test systems are needed for mobile communication modules (eCall, NAD, and so on) in the automotive industry. These test systems feature run-in screening testers, which evaluate eCall modules in parallel within a climate cabinet. These testers must perform an entire function test of devices under test including extensive RF tests. At this session, learn how you can use the NI vector signal transceiver to implement the RF measurements on nonsignaling bases. Also explore how special systems are designed for flashing, calibration, and packaging of complete NAD modules and examine NOFFZ UTP tester platforms with NI-MCT chassis.
Track/Summit: Automated Test Systems
Speaker(s): Enrique Gutierrez, Head of Test Equipment and Fixture Construction Peiker Acustic GmbH & Co. KG
Markus Solbach, Managing Partner Noffz Computertechnik GmbH
