PXI
unit accelerometer
Hi.
I have a problem with units in measuring the acceleration. I builted application with LabView 7.1 and I could normaly measure acceleration in meter/ square seconds. Than I changed the computer and install all software that need: LabView, Sound and vibration tookit and all device drivers. It is the same version of software that on the first computer installed from same CD.
Problem is that I can't chose units meter/square seconds when I create a virtual channel in DAQmx. I choose Analog Input Aceleration measuring but only possibility that it offers me for units choose is g or From costume scale. I know that I coud cinver g units to m/s^2 but it's easier thet way.
Application is the same as before I changed the computer I install software.
Tkank you
Best regards Urban
(3,147 Views)
Urban,
I’m not aware that DAQmx had m/s^2 as a built in option. I suspect that on your previous system you may have had a custom scale defined for this. Any way, that is the route I would suggest.  You can create custom scale right in MAX (Measurement and Automation Explorer) make the adjustment for m/s^2, and then use that scale. That way it is completely transparent to your LabVIEW program. Any way, that is what I would recommend and I would also recommend putting in a product suggestion for adding in m/s^2 as a built in option. You can do that at the following website. Hope that helps out!!
-GDE
(3,125 Views)
Hi!
I used the solution as you suggested and it works. I created a costume scale for m/s^2 with LabView New Scale (DAQ Assistant).
Thank you for your help.
Urban
(3,108 Views)
