PXI
speeding up PXIe-4138 measurements
I have modified an example VI to source voltage and continuously measure current from my PXIe-4138. However, it could only take about 4 measurements per second, which is not at the speed that I need. how can I make it measure faster. there are 2 channels because a I am sourcing another voltage simultaneously that is supposed to affect the current measurements.Capture.PNG
(1,602 Views)
Try stay in loop only measure VI and initialization out of loop.
(1,538 Views)
I want to be able to change the applied voltage manually and observe the change dynamically.
(1,525 Views)
Accepted by topic author Walid20
For example. Is it suitable for solving the problem?
(1,521 Views)
Thank you.
It worked for 2 channels as well
(1,512 Views)
