PXI
read the generated signal on speaker using PXI-5412?
hi all
i have some experimental setup in which iam rejecting noise & iam using Labview 2010 & PXI devices
my steps are
1. i have to generate noise signal of frequency 139.65 Hz, 160 Hz and 300 Hz? i have done using  fgen soft front panel & reads it on using PXI-5412 with the noise speaker
2. i have measurement mice and performance mice which use as sensor to read the signal from speaker
i have used   NI scope and NI PXI-5105 digitizer thre channels to see the signals
but i have issue that i want to read signal which is generated using NI scope on my output speaker....
how can i make Vi for that i have search some examples but not getting exact results..
could any one will help me
thanks
(3,299 Views)
I'd like to clarify your external setup.
1.  Generate signal on 5412 and route to a speaker.
2.  Use microphones as sensors to input signal into 5105.
3.  Acquire signals using 5105 and NI-Scope driver.
You would then like to playback these signals on your speaker.  Are you trying to take your raw data acquired in NI-SCOPE and convert it into some file format that can be played over your speaker?  Or are you trying to take your data and output it using the NI-FGEN soft front panel.
Is the trouble in handling the NI-SCOPE acquired data and manipulating it into a format that you can use?
Jon S
(3,261 Views)
