PXI
pxi 8186 crash
Problem Description :
on boot following messages appear:
nidevld--205--Fatal Error-failed to connect to MX5
nidevldp--206--tDeviceLoader.ccp MAX configuration files may be corrupt
this has happened before. fix was to reformat the hard drive and reload
everything. now it happens again.
What is corrupting the disk?
How do I get a stable system that can be used in production testing?
I can't have systems that continue to crash in a production environment.
(3,510 Views)
Hello shall!
I am sorry that you continue to have this problem.  This is definately not a common problem.  My first question is are you running XP or a Real Time OS on your system?  Does your system work normally for a period of time then these error messages appear and you are forced to reformat?  When you say on boot at which point in the boot sequence do these occur?  Let me know these details and we will go from there.  Have a great day!
Allan S.
(3,495 Views)
Hi Friends
There is always a better way to do things.................. "Just Find It"
(3,388 Views)
