PXI
pxi 5411 & Arbitrary function generator
I have a problem with the vi "NI FGEN Express (Arb)" when trying to output a simple sinusoidal waveform by means of the device "PXI 5411".
The vi named "NI FGEN Express (standard functions)" works perfectly, in fact  I obtain on the oscilloscope a perfect sine waveform at any frequency between 1-5MHz with an amplitude of 1V.
Instead using the "NI FGEN Express (Arb)" the output signal is a bad sine at 10kHz and a no-sense signal for frequencies higher than 1Mhz, even the sampling is set to 40Mhz.
The vis are completely automated, so where is the error?
Eng. Fabrizio PATANE'
fabrizio.patane@uniroma1.it
Department of MECHANICS and AERONAUTICS
University of Rome "LA SAPIENZA"
Tel +39 0644585585
Fax +39 064881759
Address: via EUDOSSIANA 18 cap 00184 ROME, Italy
(3,629 Views)
oops, the platform in Labview 8.2
Tel +39 0644585585
Fax +39 064881759
(3,625 Views)
oops again, the platform is NOT Labview 8.2, but:
Labview 7.1
(3,623 Views)
