PXI
ni pxi 6133 two channel triggering
I have a ni PXI 6133 mounted on NI pxie-1071 chassis controlled by ni pxie-8735.
I have 4 analog input channels and i would like to have an 'or' trigger on two of these channels.
It's possible to set two trigger sources?
Riccardo
(5,171 Views)
Hi Riccardo,
it is not possible t o set two trigger sources for the same channel (setting the second trigger source overwrites the first) so it is not possible even for two different channels.
You can try to route the trigger path internally (to verify if it's possible select your device from MAX and look at the table in "Device Routes" tab.
(5,146 Views)
