PXI
how to read ACK and NACK?
I’m using NI-Digital in LabVIEW to test an I²C-based interface.
The block diagram flow is:
  1. niDigital Initialize with Options
  2. niDigital PPMU Configure Output Function
  3. niDigital PPMU Configure Voltage
  4. niDigital PPMU Configure Current Limit Range
  5. niDigital PPMU Source
  6. niDigital PPMU Measure (Voltage)
  7. niDigital PPMU Measure (Current)
  8. niDigital Load Pin Map
  9. niDigital Load Specification Levels and Timings
  10. niDigital Apply Levels and Timings
  11. niDigital Load Pattern
  12. niDigital Create Source Waveform
  13. niDigital Write Source Waveform
  14. niDigital Create Capture Waveform
  15. niDigital Burst Pattern
  16. niDigital Fetch Capture Waveform
  17. niDigital Close.vi
In Digital Pattern Editor, the pattern runs correctly and the ACK is captured as 0,0,0.
However, when I execute the same sequence from LabVIEW, the captured data shows 1,1,1.
Are there any debug methods available as labview is not showing/receiving any error also.
Message 1 of 1
(94 Views)
