05-28-2021 01:24 AM
I installed 6070E board to a spare slot of PXI-1000B to see if 6070E card is ok ,after that I have put 6070E card back to the original slot when running LabVIEW runtime error 10401 happened see attach ,how to solve this issue ? My process unit is PXI-8176 . I have refreshed NI MAX remote system.
06-02-2021 02:29 AM
Hi perrycgg,
I hope you are well and safe!
May I know in which slot you put your PXI-6070E? And what do you mean by the original slot?
Was everything working before the movement?
Best Regards,
Edgar Umrikyan.
06-07-2021 09:46 PM
Hi Edgar
Thank you for help
I put PXI-6070E in slot 7 original slot is 4.
Before SCXI-1162 was burned everything works ok.
Best Regards
06-07-2021 10:21 PM
HI Edgar
attach is my work environment PC is windows 10
B/R
06-09-2021 03:23 AM
Hello perrycgg,
Could you please check your Chassis and Controller is a compatible version of the PXI platform?
NI PXI Platform Services Hardware Support - NI
Also, in your attachment, I saw that your system not installed the DAQmx driver. Could you please check which version of the driver compatible with your devices and install the right version, you can check it based on this article:
NI-DAQmx Device Support for Selected Hardware - NI
Best Regards,
Edgar Umrikyan.
