PXI
debug subVI within RT executable
I have a startup executable VI for RT.  However, there is a problem within a subVI of the startup VI.  It only shows up in the executable version.  Is there a way to debug subVIs within executables?
(3,146 Views)
Hi faustina,
When you build your RT executable you can make it a debuggable. After you deploy it, you can choose Operate»Debug Application or Shared Library... from LabVIEW. This way you can use standard debugging tools.
On a side note, what problem are you finding with the subVI? Is it not running or just giving incorrect results?
Tanya Visser
LabVIEW Group Manager
(3,136 Views)
