PXI
What is the difference between a reset and a soft reboot through NI MAX for a PXI controller 8187?
What exactly happens when a PXI 8187 controller is reset?  Also, what happens when it is soft-rebooted via NI MAX?  Are more registers being cleared with the reboot as opposed to the reset?
(3,420 Views)
Hi there,
They should behave the same.  It is a complete restart of the system.  Are you seeing different behavior between the different reset methods?
Scott A
SSP Product Manager
(3,408 Views)
Yes we are seeing slightly different results.  Are there any additional registers that are cleared when using the soft reboot?  We use a Windows OS PC to command our PXI-8187 and various other test instruments.  Sometimes the entire system hangs (times out) and a reset commanded by our software does not clear the problem, but a soft reboot through NI MAX does.
(3,406 Views)
