PXI
Veristand deploy error on PXI with Pharlap
I have a Veristand deployment error using a PXI target machine after that a switch from a project "X" (where i test CAN BUS with PXI-8513)  to another project "Y".
I use project "X" to execute a stand alone test with PXI-8513 board then I want to integrate it in project "Y".
When I try to deploy "Y" project, I can't do it with the error in attachment file. The only way to solve it is to (every time) re-install NI VeriStand Run-Time Engine to the target using NI MAX.
It is really annoying. Any idea how to solve it?
(423 Views)
Why can't I download/modify the attached file?
The website says I am locked with following cloudfare ID: 90667a240921ea56
(377 Views)
