06-25-2008 05:01 PM
I’m trying to continuously record pressure data from a PXI-5105 digitizer at 200kHz and thermocouple data from a PXI-6221 DAQ at 1kHz. I’m using a PXI-1033 Chassis, ExpressCard, and a laptop along with the Digitizer and the DAQ.
I’ve tried a few times to record the data at the same time but I’m only able to get the DAQ or the Scope to run at a time. Currently, I’m using the example, “niScope EX Save to File – HWS Low Level – Single Channel Stream.vi” with the DAQ running in a separate parallel loop in the same VI. The DAQ runs fine but I get the error, “Maximum time exceeded before operation is completed.”
Is it possible to continuously acquire data from both sources at the same time? If it is, what should I watch for to be able to do this?
06-26-2008 04:25 PM
06-27-2008 12:17 PM
I changed the rate on the digitizer to 250kHz and the code worked perfectly. It seemed like anything below that rate and NIscope would give me that above error. I’m curious to why this might be the case or if there was a way to get around that limit.
I’m using code very similar to the DAQ example, “Cont Acq Thermocouple Samples-SW Timed.vi” in parallel to the other example.
Shawn
06-30-2008 03:54 PM
Hi Shawn,
I was under the assumption that you were receiving the error with the DAQ loop. The error meant that your scope acquisition was timing out. What were you using as the record length for your acquisition? The example was set to record 2000000 samples for each record. You were acquiring data at 200kHz which would take 10 seconds to acquire that amount of data. The timeout value for the Fetch VI was set to 5 seconds by default in the example. The change to 250kHz would allow the card to acquire that amount of data in 8 seconds. Did you change the timeout value?
