PXI
Testing 7833R and9151 Expansion Chassis
Is there a test one can run to determine or isolate what problem may prevent the PXI 7833R from seeing C-modules (9853) in a 9151 Expansion Chassis? I can discover the 7833R but regardless which of several different C modules in the 9151 chassis the report is "No modules found".
Yes, we have tried both connector 1 and connector 2, same result.
We suspect either the 9151 or perhaps the cable, hoping it is not the 7833R.
EcoCAR Advisor
(3,039 Views)
It could that the fuse is blown and cannot power the chassis and modules, see this KB:
Why Aren't the Modules in My NI 9151 Detected?
http://digital.ni.com/public.nsf/allkb/3A8B84C6E3A60C12862575F00063EB80?OpenDocument
(3,022 Views)
