PXI
SMB-2163 trigger input with NI-5422
hello,
i have a waveform sequence to generate with the NI-5422, and my program need 3 trigger source.
the NI-5422 have only 2 trigger input.
i connect the SMB-2163 to the 5422 but i can't use the 3 PFI input !!!!
- can i use the DIGITAL IO trigger of the SMB for my application ?
- if no, can i use the TRIGGER input of the NI-6653 ?
if no, how can i solve this problem !
thanks.
(3,333 Views)
Hello.
Do you find an answer about your issue?
I think it's possible but I will check. You should pay attention to the synchronisation.
Regards.
Romain D.
National Instruments France
(3,303 Views)
hello,
thanks for the reply.
I tried many VI without a result. so for the moment i'm looking to find a hardware solution.
Regards.
(3,301 Views)
