02-19-2003 11:29 PM
02-21-2003
09:42 AM
- last edited on
03-30-2026
04:59 PM
by
Content Cleaner
Hello
Are you using the activex wrappers generated by the classwizard in Visual Studio or are you using the custom made CNi wrappers for datasocket.
The custom made CNI wrappers are provided with a seperate software package called Measurement Studio Controls for Visual C++. These wrappers are alot easier to use than the classwizard wrappers and have been optimized for use with Visual C++. It provides several examples to show how to use the controls.
If you are using the classwizard wrappers,You can find examples for datasocket at the following link:
ftp://ftp.ni.com/support/compworks/samples/
There is a zip file called CW3VC.zip that has a datasocket example folder that will show you how t
o start using the datasocket control correctly.
I hope this helps
Bilal Durrani
NI
