11-21-2009 07:50 AM
I have a system with an 8176 controller running XP. NI PXI-devices are not detected plug and play. Latest XP and NI patches updates. The system has 512MB ram and >10GB free disk space. No "yellow marks" ion the device manager except for the PXI boards.
I have several different PXI devices, 6608 timer, 4461, 5406 etc. None is PNP detected.
This works: Controll panel => Add Hardware etc
Device manager => Data Aquisition Devices => "Detect new hardware" does not work
Whenever I update MAX, all the PXI devices go back to being un-detected, with a yellow exclamation mark in the device manager, and in MAX the device has an "X" mark, and an outline symbol only.
Repeating Controll panel => Add Hardware etc finds the hardware and then things work fine from there again.
I have tried removing all boards except the 6608 timer but it's still not detected.
Any ideas? Is it possible that I miss some software component?
Thanks in advance
Solved! Go to Solution.
11-21-2009 10:08 AM
11-23-2009 05:53 AM
Actually, the solution was another one.
It seems Plug and Play is not supported over Remote desktop, which I was using to connect to the PXI controller. It seems the plug and play user interface is only interacting with local desktops.
