PXI
PXIe rack control via PC card
I am using a NI ExpressCard-8360 with a NI PXIe-8360 (to control a NI PXIe-1062Q chassis).
I would like to use the same chassis and the same controller with a laptop with PC-card slot instead of ExpressCard slot (the reduced communication speed is not a problem).
The laptop is a Dell Inspiron 8600.
Can an adapter from PC-card slot to ExpressCard slot work in this case?
Is there any other NI product that would allow using the PC- card slot?
Can such a solution work, considering that other Dell Inspiron laptops are supported?
Thank you very much
(3,250 Views)
I don't believe there are any PC-card slot to ExpressCard adapters that would work.  The ExpressCard-8360 uses the higher-speed PCI Express interface in ExpressCard instead of USB, so adapters from USB or CardBus won't work.  I don't know of another laptop solution for PXIe either, though for PXI there's the CardBus8310.
I hope that helps.
- Robert
(3,229 Views)
