01-22-2018 09:34 AM
Does anyone have any experience with NI-TClk with a dual channel PXIe-5423. I have two dual channel cards that I need to synchronize. The synchronization on one dual channel module should be automatic, but I need to synchronize with the other module too. Previously I was using NI-TClk with 3 PXIe-5422 arbs. Eventually I would like to have four channels, which is part of the reason I upgraded. My existing code for NI-TClk doesn't work, so I'm hoping someone has done this before with these new modules.
01-23-2018 10:26 AM
I haven't seen examples for something like this specifically, can you elaborate on what you have tried and any parts in which you are having difficulties.
01-23-2018 11:32 AM
Here is the example from NI "C:\Program Files (x86)\National Instruments\LabVIEW 2015\examples\instr\niFgen\Fgen Arb Synchronize (TClk).vi", it works with two PXI-5422 modules but doesn't work with two PXIe-5423 modules. I put in a help ticket with NI and they asked for a MAX report and the exact error, which was -250032, niTClk Configure for Homogenous Triggers.vi:2010001
01-25-2018 06:36 AM
NI Support: “Currently we don't have TCLK support for our newer arbs (5413, 5423, and 5433), but we are working on adding this”
10-07-2019 03:59 PM
In case anyone runs into this question again in the future, all PXIe-54x3 devices have NI-TClk compatibility as of NI-FGEN 18.1.
10-17-2019 08:14 AM
Thanks for letting us know. I'm glad it's supported because I'm resuming my project and I hope this works.
