PXI
PXIe-1085 Chassis - need help with module selection and connection
I am using a PXIe-1085 chassis.  I need to find a module to use that will provide a +5VDC and -5VRTN to eight external devices.  Each of these devices has an input current of 25mA.  Which module would be the best to use?  Also, what pins on the module would I connect to?
The external devices have the following pinout:
Pin A: +5VDC
Pin B: -5VRTN
I really appreciate any help you can provide me with.  This is my first time using the NI PXIe equipment, so I'm very new to this.
Thank you!
(2,306 Views)
Are you looking to power up your eight external devices which requires +5V and -5V rails from PXI chassis?
You have a wide range of PXI power supply or SMU modules from NI that can provide +5V and -5V.
1. Do you need individual control of the device power supplies?
2. Is there a requirement for a precise power supply, i.e., should it have a kelvin connection?
3. Please let us know what exactly is the device
4. Do you want to communicate with your external device from a PXI instrument?
Santhosh
Soliton Technologies
(2,283 Views)
Hi Ghostie,
For product recommendations, your best route is to contact our sales team at (888) 280-7645. They will be able to help identify the right options for your specific application.
Kevin S.
Technical Support Engineering
(2,274 Views)
