04-13-2021 09:19 AM
Hello, it is possible to add to PXIe 1071 modules PXIe 4492, PXIe 6363, and PXIe 8301? The connection to the computer would be via PXIe 8301. Thank you
Solved! Go to Solution.
04-13-2021 06:05 PM
Yes, your modules are compatible with each other.
Make sure to configure the inhibit switch to controlled by the power button directly.
04-14-2021 06:07 AM
Thank you for you reply
04-14-2021 06:13 AM
I have one more question, why is it not possible to connect PXIe 8301 module to the PXIe 1073 box?
04-14-2021 07:46 AM - edited 04-14-2021 07:46 AM
8301 is a Thunderbolt based alternative to the MXIe or embedded controller. You can use the 8301 only in the chassis that supports an embedded controller.
As you can see in the PXIe-1073, there is no controller slot and this chassis is designed to work only over MXI with an inbuilt MXI controller.
04-14-2021 03:02 PM
OK, thank you very much
04-15-2021 07:07 PM
Please mark the appropriate post as a solution if you got your question answered.
