PXI
PXIe-1065 Open on power
Hi ,
I have PXIe - 1065 and it's a part of a big system all the system controlled by one Power switch.
I want the PXI to be Init ( ONLINE ) when I press the main power supply...
I'm guessing there is a switch or a jumper inside the PXI , any one know where or you can give me a link to a manual... ?
Kobi Kalif
Software Engineer
(4,010 Views)
Accepted by topic author Kobi_K
Hi Kobi Kalif,
If I'm understanding you correctly, you would like to power on your chassis when your line power is applied to your chassis?  If you would like to override the power switch on your chassis, you can set the inhibit switch on the back of your chassis to 'manual'.  This will allow your chassis to power on automatically as soon as line power is applied. To learn more about this option, and other possible solutions, please check out the KnowledgeBase Article I linked below.
Remote Power of PXI Chassis
NI PXIe-1065 User Manual and Specifications
-Brandon G
Precision DC Hardware Engineer
(4,004 Views)
