PXI
PXI module delay _Pulsed SMU
I asked about trigger routing and timing over on the LabVIEW forum but haven't found a solution to my problem. So I would like to explore hardware options for triggering.  https://forums.ni.com/t5/LabVIEW/PXI-delay-between-modules/m-p/3889714#M1103263 Sorry for "double post".
Using PXIe-4137 (qty 2).
I want to trigger a Pulsed Voltage measurement roughly 7 ms after the first SMU begins a measurement cycle (40 ms total).  But it seems I can't get the timing i want with these two modules alone.  Do I need a hardware solution here?  For instance, can I use a PXI-6683 synchronization card?  Route PF1 to the PXI backplane to function as a trigger-in connection?
Message 1 of 1
(1,938 Views)
