PXI
PXI hardware recognized in Measurement and Automation but not LabVIEW or Signal Express
I have a new PXI system (PXIe-1075, PXI-5661, PXI-5154, and others), which was put together by NI-folks. All the hardware is recognized in Measurement and Automation. I installed LabVIEW 2010 but it seems like LabVIEW or Signal Express doesn't recognize the hardware at all. Any suggestions?
Thanks!!
(3,396 Views)
Hi CptRon,
Thanks for posting. Could you explain a little more what you mean when you say that LabVIEW or SignalExpress doesn't recognize your hardware? My first thought is to make sure that your software was installed in the proper order. Programs such as LabVIEW or SignalExpress should be installed before the drivers for your devices, so if you installed in the opposite order, you may have to modify your driver installations to add support for SignalExpress and LabVIEW.
To do this, navigate to the Add/Remove Programs dialog, then select National Instruments Software and click Uninstall/Change. Select the drivers associated with your devices and click Modify. Then make sure that support for your version of LabVIEW is set to install to your system. Let me know if this helps!
Joe S.
(3,377 Views)
