PXI
PXI Device Communication Interface
Hi there,
Could you give me some advice for the sensor current measurement with multiple channels? We have a PXI switch matrix, the PXI-2535, along with a PXIe-1073 chassis that we use to measure the sensor device current. I was wondering what the difference is between the PXI-2535 and the PXI-2530B? Which one would be preferable for a multichannel measurement application?
Thanks for your help.
Best,
Ashik
(801 Views)
One is Reed relay based, and the other is FET based.
Here is a quick comparison of the relay types,
Depending on the signals, you may or maynot need electrical isolation and the choice.
Santhosh
Soliton Technologies
(760 Views)
Hi Santhosh,
Thanks for the helpful information!
Best,
Alam
(753 Views)
