05-05-2009 04:45 AM
05-06-2009 11:56 AM
Hi Paul,
A few things to look at would be (since this appears to be a timeout issue) to change the Transfer Mechanism to see if you still get the same error. As well, I'm curious, what Rate do you have it set at in your test panel (please try adjusting this to see if you get the same error)? Does this error occur on all channels? Have you had this device in the past, and has it worked then? Does it work in a different computer?
One other thing to check would be to see if your power requirements are being met. This device is one of a few that requires both a 5V supply and a 3.3V supply from the PCI bus. You'll want to verify that your motherboard has a 3.3V supply for the PCI bus before doing other troubleshooting (found in the specifiations here: http://www.ni.com/pdf/manuals/322080e.pdf#page=67).
As well, Does your device pass a self test? Let me know what you find out!
05-07-2009 03:58 AM
Hello Thank you for you reply.
Here is a list of answers to your questions.
1. The error occurs with DMA or interrupt transfer.
2. The rate is set at 1 kHz and there is no dependance of the rate on whether the error is produce.
3. The error occurs on all channels.
4. This has not happened before when I have used the test panel with this card.
5. The card is used inside a PXI box. All other card in the box function normally.
6. The card was working before so it probably isn't a power problem. Static Updates work normally.
7. The card passes the self test.
It seems very strange to me that static update for, but waveforms don't. I made a test task, where I vary the number of sample I send the device, and the rate. But the error always occurs no matter what the conditions of the waveform. Could it be a memory buffer on the card which has developed a fault?
thanks,
paul.
05-08-2009 04:44 PM
Hi Paul,
It sounds like there is something wrong with card where it's not correctly transferring the data. In your case, I would recommend sending your card in for RMA. You can do this by calling 1-866-ASK-MYNI (275-6964). Thanks!
