PXI
PXI 6570 digital patter editor question
Hi all,
I am using PXle-6570 module card
may I know what is the difference between the system pin and DUT pin state in the pin map editor inside the digital patter editor software?
Message 1 of 13
(1,767 Views)
A System Pin is common to all Sites, a Site Pin exists on each site.
I would recommend you taking up this course to better familiarize with the instrument - https://learn.ni.com/learning-paths/device-testing-with-digital-pattern-instruments
Or you would end up spending several weeks or months just you get hold of the basics through the forum and material available.
Santhosh
Soliton Technologies
Message 2 of 13
(1,749 Views)
Hi, Santo
thanks for the reply.
I have 32 pins DUT needed to test in pxle 6570 using 8 sites means 1 site connected 4 pins of DUT and the ni software shows me some error:
Warning. An error might occur at run-time. The following pins in the pin map are not connected: DUTPin10_PA - Sites: 0, 2, 3, 4, 5, 6, 7
may I know how to solve this issue?
Message 3 of 13
(1,736 Views)
Probably you got the basics of Digital Pattern instrument all wrong.
How many pins of your DUT are actually connected to 6570? and how many site?
Please share your PinMap
Santhosh
Message 4 of 13
(1,727 Views)
Hi Santo,
Actually, I do not understand the concept of a site could you explain more about it?
Below is the DUT pin I needed to test
Message 5 of 13
(1,716 Views)
In that case, you are in not the right skillset to program and use a 6570 instrument. I would highly recommend taking up this course - https://learn.ni.com/learning-paths/device-testing-with-digital-pattern-instruments
You've 17 pins of your DUT connected to 6570 but you want to test 8 sites.
17 pins per DUT x 8 sites = 136 channels but a single 6570 has only 32 channels, do you have extra 6570s?
Santhosh
Message 6 of 13
(1,706 Views)
Hi Santo,
This course already missing I cannot find it
Do you know what is PPMU?
Message 7 of 13
(1,701 Views)
@AlexPXI wrote:
Hi Santo,
Oh, actually your company has to purchase the course.
PPMU - Pin Parametric Measurement Unit
This is like a high density low power Source Measure Unit, you use this feature to power low-power devices, perform basic tests like continuity and digital leakage.
https://forums.ni.com/t5/Digital-I-O/PXIe-6571-PPMU/td-p/4211800
Santhosh
Message 8 of 13
(1,691 Views)
Hi Santo,
thank you for your reply
After I study the datasheet I still did not understand what is Vf, If, Vch, Vcl, and I range could you elaborate more?
and the site in the pin map editor what mean by site?
Alex
Message 9 of 13
(1,683 Views)
Unfortunately, this will end up me training you over the forums, which is quite demanding.
As I recommended, please ask your company to purchase the course, so you can be trained to do your job effectively.
Santhosh
Message 10 of 13
(1,676 Views)
